firepete999
hi I'm having issues with no power and van going into limp mode and error code p0238 it happened once last year but i cleared the fault and was ok for last to long journeys at end of 2022. the van has been sorn over winter but now fault has come up and i cant clear it .
i have just changed the map boost pressure sensor for a new one and removed the inlet manifold and cleaned everything up.
but on first drive it lacked power and then engine light came up and was worse again .
i have removed the boost solenoid and suspect this might now be the problem as i cant hear it clicking if i put 12v on it .and i put a vacuum pump on one side and it did not release suction when 12v was applied . [does this look like it could be the issue ?] would this bring up a p0238 code .
i checked the voltage on the map sensor unplugged and got 0v 0n pin 1. 4,6v on pin 2 .5v on pin 3 .and 5.7v on pin 4. if i plug it in the pin 4 drops to about 2.6v so I'm quessing it is probaby ok .i want to check wiring from the sensor to the ecu but cant work out how the plugs come out the ecu .
any help most appreciated .
