- Joined
- Mar 12, 2011
- Messages
- 6
- Points
- 2
Please can I request help with my Ducato 11 JTD.
I have recently purchased a 2005 write-off with a view to transferring the running gear to my old 2.0l Boxer campervan - a major job I know, but I think I can do it. Anyway, I've cleared-out all the broken bits of bumper, aircleaner and headlight and bent back the bodywork to the point where I'm pretty clear that there's no damage to the loom, ECU, rad, MAF etc. I've reset the cut-off inertia switch.
When I try to start the engine it nearly fires on first pull but thereafter there's no hint of it running. I've checked for fault codes via OBDII but there are none. However I loose connection on cranking - indicative of insufficient voltage? However cranking speed seems OK.
The in-tank lift pump runs for about 8 seconds on initial switch-on and, during this period, the external direction indicator lights come on steady - is this correct? I found evidence of some additional electronic equipment having been fitted behind the dash - perhaps a tracking device or additonal immobiliser - but this appears to have been removed/snipped-out. However I want to be sure that there's no residual 'black box' flashing the indicators and stopping the engine running. BTW the key seems to be recognised fine.
When running the lift pump makes a clicking type of noise rather than a buzz as I experience with my Xsara HDi with the same engine. Is that correct? I will try to measure the supply pressure tomorrow as I suspect it may be at fault - a trickle of fuel issues from it when running disconnected rather than a spurt as I'd expected.
Please could anyone comment on my observations or suggest a sequence of diagnosis, or point me to the most likely causes of non-starting?
Thanks,
Stuart
Thanks,
Stuart
