I have a hypothesis, and am looking for someone to rubbish it.
I noticed that distinctive drop link failed noise a few days ago.
Whilst investigating the noise (which I refused to believe was drop links because they were new), I discovered a broken spring. Only the last 100mm or so, but enough to push the strut out of line.
Replaced that, and then noticed anti roll bar looked asymmetrical. Measured it, and found it was about 75 mm away from central, pushed in the direction the failed spring was moving the strut.
So, my hypothesis is, the spring broke, gradually pushed the arb across (I know it was central to start with because I made it so), which put unexpected stresses on the drop links, which caused them to fail prematurely.
Anyone had same? I know drop links fail on our beasts, but 2 going within a year of fitting (from different suppliers) seems a bit much. Have replaced the worst one from my stash (the ball popped out of the socket with hand pressure), and the noise is only on the other side now.
