Hi Doblo owners,
I got a 2006 Doblo 1,3 multi jet (119) and it's now I 'limp-mode' because of an engine failure telling that the efficiency of DPF (cannot remember the code).
The thing is, that I changed the DPF (and its temperature sensor) a year ago and I'm not sure that the ECU had been reset back then and therefore it kinda makes sense if the ECU 'thinks' that the DPF should be inefficient.
The DPF and regeneration cycles has been quite 'normal' since the new DPF was changed.
I think I need a forced regeneration and a DPF reset in the ECU, but I think it's hard to find out which OBDII cable and software I need to perform these things?
I bought this and hope it's the right one?
" Interface Autodia FOR FIAT ALFA ROMEO LANCIA OBD 2 Diagnostic OBD2 Tester USB EM327 "
And want to try MultiEcuScan, BUT is the free version capable or should I buy a
license?
Kind regards,
Aron
license?
Kind regards,
Aron
