If you put the door check strap on upside down the window will shatter when you close the door because it will catch the glass. all you need to do is unblot the check strap and turn it the right way. ( that is providing you have had the problem since you changed the strap.)
I had the same problem with my car, i didnt shattered the window, but it was very close!
