woodbine66
- Joined
- Nov 19, 2015
- Messages
- 33
- Points
- 64
I don't want to say which Fiat I'm referring to, as the mods will probably move this thread to the appropriate model forum where it will get few views and zero posts. The vehicle I'm referring to has the 2.0 HDi engine and is from 2004.
The other day I went to change the speed sensor on the differential because the speedo, odometer and trip meter stopped working suddenly. At the same time I started getting hesitancy in lower gears, so thinking the sensor is broken and not sending speed info to the ECU.
Anyway, due to poor access I hired a rent a ramp car lift for a couple of hours. I pulled the old speed sensor out, losing a fair bit of gearbox oil in the process. When I pulled the shaft with gear on it out of the hole in the sensor, I could see that the old sensor had no square drive up inside the hole. However, the new Febi sensor that is identical in all other respects has a square drive up inside the hole that stops my original shaft going in as far as it should go. Please see photo, you can just make out a square drive inside the hole. So I was unable to fit the new sensor.
My question - do some speed sensors of this era for the 2.0 engine have a square drive up inside, and others have nothing up inside the hole? The new Febi sensor says it should be compatible with the Fiat part number - I checked on Eper. Any advice or knowledge of older speed sensors would be appreciated - inc. poss. info on testing these units.
