Dodgy noise from wheel
G
Gary
Hey guys, wonder if anyone can help me.
Right, when turning right, at speed, or sharply, I get a kind of 'tick tick tick' noice coming from the drivers side wheel (I think). I'm not sure what this noise could be. Anyone got any ideas? Or anything to look out for? The brake pads aint been changed in about 10,000 miles, but to be honest, it's been mostly motorway driving if it makes a diffrence, and they seem totaly fine. Any idead?
Thanks!
Go easy, I'm not too mechanically minded.
I've got a 1.2 51 Reg, 43k
arch liner catching maybe?
Pete
BravO 1.8 GT (Import)
T reg 1999
Abarth Kit, Leather, Power Flow Cat back,
Sparco Strut Brace, JBL Sub, Crap amp!
Marea Console in Progres :) Gettin there
Dash Spraying in Progress :) Centers done!
I meant turning left by the way, hehe.
I'll have a feel around later, cheers!
That sounds wrong.
Gary
sound to me like your cv joints are on the way out/is the clickin coming from driver side?
just slide of gator and pack with grease/ that stops the clunking noise
the longer you leave it the worse it will get
It's from the drivers side yep.
Balls :( Just when things where going well, any ideas on prices? Or checks to make sure this is the problem? Is it likely that the wheel will fall off if I don't get it replaced soon?
Thanks guys.
Gary
same happend to mine on hgt
the grease sorted it out,mine was seriously clunking but now gone.
i did look into new cv joint,fiat quoted 87 quid for part(hgt)
a local part dealer quoted 42 quid(hgt)
just show you have to ring about
Where exatly would I need to greese? Would good old Haynesy show me how it's done?
Gary
right here we go/this should take about 5 mins
1st turn wheel full lock to right
2nd jack up car so wheel is off the ground
3rd pop ur head under and you will see black rubber gator on drive shaft(close to back of brake disc)
4th slip the widest part of gator back to reveal cv joint (bearings).and pack with grease be very generous with it apply grease and turn wheel apply grease and turn wheel apply grease and turn wheel apply grease and turn wheel
5th slip gator back on and lower jack and off you go with hopefully a smooth ride
its worth 5 mins and a couple of quid of grease,rather then £47+fitting
Cheers man, I'll give that a go when I've got a minute! If that don't work I'll get the wheel out and make sure there is nothing out of place. Anything else to look out for? Would it not be advised to get this part from scrappy? Moneys tight right now :(
Gary
K
2
1K
Dark Lurker
922
David
R
802
R
M
1
525
Dark Lurker
G
5
1K
sam ng
S
