Technical Doblo not starting
Djoauto
Tamworth
Hi hope I’ve posted in The right place. I have a problem with my 2011 DOBLO 1.4 petrol 12k. The other day I was fixing the handbrake. As it was hot I started the car up to have the air conditioning on. It was ticking over fine then it just stopped running. I thought it was out of fuel as I knew it was low. So day after put some fuel in it and now it won’t start. Turns over fine as it should but won’t fire up. I sprayed some easy start in the air intake and it fired up instantly and ran as it should and ran fine till it burnt of the easy start. It was at this point I noticed when I turned the ignition on there was no sound from the fuel pump like there normally is when the ignition is turned on. Are there any common faults on these or anything somebody could recommend to look at to try and fix the vehicle.
Thanks.
Dave.
Model
1.4 petrol
Year
2011
Mileage
12000
