- Joined
- Aug 8, 2015
- Messages
- 2
- Points
- 2
Hi, I have a 2016 Doblo Cargo Maxi 1.6 198A3.000 Euro5 engine and first start after being left overnight the oil pressure light take a couple of seconds to go out and the warning for low oil pressure comes up on the display. It only does it after being left overnight . I have changed the oil and filter removed oil pressure switch and tested it, It operates at 0.2 bar. The engine runs at just over 4 bar oil pressure from cold. It appears to be a drain back or oil pump problem . Just wondering if anyone else has had the same issue. Thanks.
