Hi all. I have a Doblo 1.9 JTD SX (53) with a problem I believe may be attributed to the master cylinder but as this my first Fiat I am not too sure.
I have just had the DMF and Clutch assembly fitted at a local garage. Had this done because the clutch pedal went right to the floor before disengaging the gearbox. The pedal only came up about .5/1” before gears engaged. My experiences with replacing clutches on several makes of car told me that the clutch was worn out, hence replacing the DMF & clutch assembly.
How ever the clutch pedal still goes to the floor and doesn’t always disengage the gearbox. Sometimes I can select reverse but usually with a bit of force (grinding) and sometimes it comes out of gear first time or I have to force it out or stop the engine.
The car has been to the garage who fitted the new clutch and dmf 3 times to be bled but always comes back with the same problem.
Any advice would be greatly appreciated as I need to get this sorted and car running correctly prior to doing work for a local charity. Other than this the car is in excellent condition for the year.
Thanks in advance.
Thanks in advance.
