Technical  Dipstick leaking
Brain picking time again! would anyone know if there are different types of dipsticks seals? I have a 126 engine with an Abarth 4 litre sump , a few weeks ago I bought a new dipstick as the old one was leaking round the rubber bung it looked perished , I assume the bung stays in the engine orifice, then the idea is you just withdraw the dipstick and when replacing it the pressure around the bung should seal it!
However i noticed a small amount of oil dripping onto the manifold from around the seal.
Also I couldn't use the new dipstick as it was too short ( my fault didn't tell supplier 4 ltr sump) so I have just used the bung. To make sure it's the correct length i have used some self amalgamating tape wrapped around the correct position on the stick, so it won't go in further than it should.
Or should the bung be fixed to the actual dipstick? But by doing that, it seems very loose ( no one wants a floppy dipstick) and tends to drip.
All comments welcome.
To the best of my knowledge, there is only one length of dip-stick. Although this won't give any indication of the gross amountin the sump, it still gives you an indication as to when to top up the sump. As Peter has mentioned, the long rubber bung (plug?) on the dipstick should be located over the locating/securing disc. The plug DOES come out with the dip-stick.
According to what you're saying the bung should be fixed to the dipstick permanently. I tried that but the oil seems to leak through slightly
I even thought of making a sealed bung with a 6" type of handle that just seals the hole, then when I want to check the oil levels i just remove it and pop in the normal dipstick. I know its not the correct way but at least it would stop the drip.
Unless there are different types of bungs available & I happen to have one that's too small & not tight enough . If anyone knows of different makes i would like to know.
Not meant as a silly comment, but being that there is a difference between the 500 and the 126 dipsticks, it is a 126 dipstick that you are trying to stop leaking?
New dipstick less than £10. Engines run hot �� invest in a new one!
Hi i am perfectly happy ☺ to buy a new one in fact that's what I am hoping to do, but I just want to know if there is a difference in the 126 & 500 dipstick also to the rubber grommet are tighter on one or the other. There is also a question why one is shorter than the other & does the capacity of the sump have any relevance, I assume the oil level sits in the sump just below the main bearings, so the length of the dipstick would be irrelevant.
Really do appreciate your interest & help in this.
Barry
I was wrong---there are 2 lengths of dipstick---the 126 BIS dipstick is shorter than the 'air-cooled' 126 dip-stick, but has the same seal/bung/plug on it. The Axel Gerstl site is selling both types of dipstick (3euro) or just the seal at 1 euro. If you do buy one from them, make sure that it is the 500R/126 version. The dipsticks are in the 'oil-supply' section of 'engine parts'.
If you have a 126 (594cc / 650cc) engine, then buy the 126 dipstick.
example, no affilation, other vendors are available and probably cheaper:
https://www.ricambio.co.uk/dipstick-classic-fiat-500-126
The dipstick reading will still be correct as in min /max. Your new sump have a greater capacity but the length of the oil intake pipe inside the sump does not change.so the dipstick is still correct in it's measurements. Just that you have more oil, which is always a good thing ;-)
cheers
Rob
Hi i am perfectly happy [emoji5] to buy a new one in fact that's what I am hoping to do, but I just want to know if there is a difference in the 126 & 500 dipstick also to the rubber grommet are tighter on one or the other. There is also a question why one is shorter than the other & does the capacity of the sump have any relevance, I assume the oil level sits in the sump just below the main bearings, so the length of the dipstick would be irrelevant.
Barry
Barry. 126 v 500 dipsticks. not interchangeable. The 500 relies on snug, slight taper and "O" ring I think...amazing they stay in at all. :)
Some measurements and/or pictures would be most useful. The o-ring on the 500 dipsticks do tend to wear loose but with the 126 ones the seals wear and also the rubber petrifies leaving the dipstick loose. As a stopgap with the latter I have slipped a small o-ring onto the seal to bulk it up a little. Sometimes where an engine has been run for some time with a loose dipstick at some stage the aluminium crankcase hole can wear making sealing difficult.
