Hi All. I've just bought a 2l SLX. The digital control to turn the heater fan up/down isn't working neither is the hot/cold button. Anyone any ideas on what I need to repair this.
denkab said:I had some problems with this electronic (clima...) air condicion with my tempra 1.6. My problem was that i didi not have air flow after some time of turning on the air condition either on heat or cool. The problem was an air flow control sensor in front of the seat of co driver. I hope this will help you
Tempra1.6 said:Hmm...
I have a 1.6 SX.i.e.cat, but I don't have an air-condition, neither a clima system...
It seems you are talking about the console that is located above the ashtray.
First of all, you should check if the whole system has gone bad. Is the air-condition working properly? The temperature selector? etc.
If the air-condition is working, and you only have problem in switching from hot to cold, and adjusting the fan speed, then, I am not sure if I can help you in an efficient way. Anyway, here is how you can dismantle the controls for the manual system (no air-condition, no clima):
Once you open the ashtray, you have to carefully notice the 2 black screws that fix the automatic clima system controls to the console. In order to know where they are located, remember the level your finger was when you opened the ashtray. These 2 screws are right there where the ashtray contacts the console when closed (I hope I am writting this the right way, so that you can understand my english...)
Once you remove these screws, try to check if the controls can be removed. In my Tempra, you also have to remove the circular controls by pulling them towards you, and then to unscrew another 2-3 screws that are hidden beneath them. Soon as you do that,the controls can be detatched from the console once you remove the screws, by pulling them from their bottom (from where you removed the screws) towards you, and then lifting them up, being very cautious not to break the hinges on which they are fixed on their top!!!
Also, once you have pulled the controls out only for a few cm (1-2 inches max), you need to remove the clips that fix the 2 small light bulbs that give light to the controls during the night (these lights are activated as soon as you open the car front lights), so as not to cut their wires!!!
PLEASE BE VERY CAREFUL WITH THE ABOVE PROCEDURE, SINCE IT IS REFERED TO THE REMOVAL OF THE MANUAL HEATER CONTROLS, NOT THE DIGITAL ONES!!!
Just try to check out whether any of these control button caps can be removed separately, hiding beneath it extra screws that fix the controls to the console. Once you check that out, try to remove the controls from the console in a similar way as described above. Do not use excessive force, it is not required. Doing so may cause damage.
Usually, digital panels are connected with special wire "plugs", that need attention on removal. Once you manage to remove the controls, it is very likely that you will have to dismantle them, so as to fix the broken control switches.
I hope this will be of some assistance to you. Good luck !!!
