voodoomark
Recently the instruments on my stilo multiwagon died (just had two warning lamps on ignition). I followed the advice on this forum; fuses, earth points and battery level and all were ok. I decided to check the pcb out, after dismantling the pod and removing the pcb I re soldered the joints on the connector and as many componants as I could (using a fine solder iron tip). The inst. pod now works correctly again.
if you have the same fault I would recommend the same repair, or use a solder reflow oven if you know someone with one, just remember to take the capacitors, connector shroud and stepper motors off as these may melt. if you are not comfortable doing this drop me a line and I may be able to help.
