Technical DASH WARNING MESSAGE (please help)
djabbey18
i got in my car the other night and started it as normal and i got an error message on the dash display saying somthing like
ABS fail or ABS error somat like that and the yellow abs light was on the dash.
i turned the engine off and re started it an the error went away
does anyone no if this is a start of a problem or if anyone else has seen this what did you do.
Mark.
Take it to a dealer. I'd only take it to the dealer if it happens again. Its usually a dirty earth connector or similar.
sledge
West Wallaby Street
Megawatt alley
I had an erratic ABS light, got my dealer to investigate and they diagnosed and replaced a suspect wheel sensor under warranty, been ok since.
Ffoxy
Telford's Own...
I had that, ignored it and never came back in 9 months, had a coolant temp warning too, when the engine was stone cold, that too went away. Still a FIAT remember! Better... but still a FIAT! (y)
Let down by the 'Bosch' components which are german :eek: :D
Ffoxy
Telford's Own...
Lmao... yes maybe Chris... but its STILL got a FIAT badge not a Bosch badge.
I love my GP and will have another unless the Bravo starts to float me boat, which it doent... yet. The GPS is the only car I have ever thought that I would have another. I need to get out more! Or test drive a 150 Mjet Bravo?
Preston
Mark.
Get it checked,first make sure body computer update has been carried out then as Sledge said get them to carefully check connections.
Known issue 'Foxy' dealer should be able to help here;)
tommy_8884
NFFC
Stratford-Upon-Avon
i had the same light come on the second day of owning my GPS, it said Hill holder not available on mine. It went away after restarting the engine
