lemaitre777
- Joined
- May 1, 2015
- Messages
- 3
- Points
- 1
Hi. I have the uno 1.4 Pacer. My car has some very funny symptoms any suggestions as to where the problem might be. Everything was was working fine. Stopped the car for bout 2 hours came back started the car but no lights wanted to light up except the hazards.
When I switch on the headlights, put the transmission in reverse or press the breaks the dash looses power (No rpm-feul and temperature readings). The Dash also doesn't light up upon starting the engine, only when slightly revving the engine does it then light up and stays on until I switch on any light by any means except the hazards.
The battery indicator is dimmed while dash has power.
Thanx guys
Thanx guys
