kybadog29
The charming children in the close where I live decided that the car would look better if the aerial was snapped off at the base and did so by bouncing a football off the roof........after thanking them with an ancient anglo saxon salutation I had to figure out how to replace it.I found a direct replacement on ebay but then found this http://cgi.ebay.co.uk/FIAT-BARCHETTA-CINQUECENTO-MAREA-STILO-Shark-Fin-Aerial-/280467008420?cmd=ViewItem&pt=UK_CarsParts_Vehicles_CarParts_SM&hash=item414d22eba4
(sorry tinyurl don't work on the craptop)there's a few things that worry me 1.It says 12v on the front(why does an aerial need to be powered?)
2.The connection lead is only 15cm long ,so what/how do I plug it in(to)?
3.The separate lead underneath which is described as the "LIVE" lead is even shorter-it goes into the base ,there's a circuit board inside and the other end of the lead comes out of the board(via a a marked position 12v)and goes into the top of the aerial housing where it ends as a bare wire taped to the inside of the housing
As the title says it fits a cinquecento so any clues as to what I do next would be appreciated(even if its send it back and buy the normal one!)
Incidentally when I tried to review the post the forum logged me out and came up with the usual carp about me trying to access admin controls (which is also carp and is usually down to lazy coding!!!!!!!!)
