Technical cut out??:<
Grim_Evil
manchester, United Kingdo
Hi, I have had problems that you lot help me sort:D
But now I have a new one, on my 899c cinq
Its been running fine since i swopped out my rad and thermastat.
But this last week i have new problem, my car start no problem, runs fine, gears work etc with no problem. but all of a suden it will just die on me, have to pull it of the road and then restart after about 2mins and it will run fine again?, it does this every so oftern, and its getting on my wick. cold it be the timing belt ??
thanks
No injector lights coming on or anything?
Tom (AofB)
Snapped exhaust flexipipe becoming GrpN ASAP!
yeah i think it is come to think about it, but not all the time, come on for a while goes out, then other times comes on the goes out as normal?
Is it accompanied by a loss in power and a shuddering...
If it is, it may be the MAP Sensor, there's a black line about 2mm in diameter that runs from the front of the engine block (below the black dome) to the blue thing at the back right of the engine bay.
Pull that line off carefully, blow through it and check no petrol comes out..If it does, that can be sorted easily, A non return valve can be gotten for about £4 I think, can find info if necessary.
Make sure the line is connected to the car when trying to start it!
Tom (AofB)
It's not the timing belt, you don't have one on an 899.
Put a spare spark plug in the door pocket. Next time it stops, dive under the bonnet, remove a lead, attach to your spare plug, earth the plug against the block and turn the engine over. If there is a spark, its a fuel problem. If there is no spark, then its ignition.
Take it from there.
Grumpy old git going fast downhill rather than downhill fast!!
