Technical Crankshaft pulley / Cambelt
Mario123
Hi, I am in process of replacing the cam/timing belt on my 1.6 16VPalio (2003 model). I was wondering whether there is a special tool required or method to hold the crankshaft in place to loosen the nut on the crankshaft pulley as I need to remove the pulley to replace the belt.
Any thoughts/guidance will be much appreciated.(y)
I'll take a photo of where the cambelt goes round the crankshaft pulley. There is a flange/metal cover right next to the belt and approx 1mm from the crankshaft pulley so I can't slip the cambelt around the pulley for the waterpump/alternator/aircon belts.
Here is a picture of the crank pulley (alternator/waterpump/aircon belts) on the left, cambelt (still in tact) and the flange (red arrow) that prevents the cambelt from being removed without removing the crank pulley.
You should be able, from underneath the car, to remove a cover over the flywheel on the other end of the engine, then carefully find a way to restrain the flywheel. I've seen mechanics here in Brazil just jam a steel bar in one tooth of the starter gear to stop it turning, but I would make something in wood to engage a few teeth, to prevent breakage. Hope this helps....
Andy
