panda_owner
Now the winter has come and my panda seems to spend 10 l/100km of fuel instead of 6-7 l/100km because of couple of things I have noticed that seems wrong. This is the first time I experience this. So, if someone knows something about this, I would be happy to get some answers to this problem:
1. in the air filter housing there is a 'switch' (not an eletrical, but mechanical, depending of temperature of intake air) that decides to take air directly from outside or from very hot exhaust pipes that comes from the engine. The termoelement that looks like spring around some cylinder object is set to take air from cold outside of car when everything is cold (I mean the engine and the rest of the car). To me, this seems to be wrong, since the purpose of this would be to get hot air when the engine is not warmed up. But I would like to know for sure.
2. Seems to me that coolant thermostat is broken and the cooling water always runs even if the engine is cold. I came to that conclusion because the water hose that runs into radiator is slowly becoming warmer. If the thermostatic switch would be in order, the hose would be cold, and then in a very short time it should get very warm, right? I'm not 100% shure about this, so tell me if I'm wrong. And another thing is that I cannot find that thermostat (his location), so please tell me where it is.
