General coupe door
General coupe door
BLUEBOY08
dundee
cant open door from inside as must have snapped off inside.any idea best way to take door off to fix handle?
It will be a white plastic clip thats snapped. Order one from fiat (less than £1) and then strip the door card off. Remember there is screws at the bottom and through the handle and also allen keys aswell. Once they are all removed the door card lifts up and off. Then you'll be able to see that the cable isnt attached to the handle because there is no clip. Replace the clip and re-fit. Job done :D
Ross
Ross
Like H2ypr says - its the little clip thats popped off the ball-thingy...
If you take the little surround cover off from around the handle, sometimes you can reach it and fix it that way without having to take the door card off, although to be fair, taking the card off is relatively easy.
