Technical Correct/best oil for grande punto 1.4 t-jet.
Jordy94
What is the best/correct engine oil for my fiat grande punto 1.4 t-jet ?
Use of products with low-quality properties than ACEA A3 and ACEA B4 could cause damages to the engine that are not covered by the warranty" - Call me thick but what does this mean ??
We'll I have just brought some Morris 5-30 fully synthetic oil ACEA C3 -10 is that any good ??
you will suffer from high evaporation and it will not with stand it's condition in high load (high boost with high RPM)
5w 30 won't do anything though will it ? Like damage anything ?
I wouldn't even use the wrong oil in my 1.2, even though that probably wouldn't even hurt it
5w-30 would start up the same but would be a bit thinner at operating temperature than the proper 5w-40.
Since you have a tjet which is not only a turbo for a start but a decently tuned engine id get some good quality oil, at the actual spec that is supposed to be used in the car :p
The car is designed for 5w-40 so use it!
