Have a 1997 Ulysse 2.0el:slayer needs flushing and coolant replaced I cant find any drainage valve. Does anyone know the correct procedure for changing the coolant for this model?
hi,
not model specific,
but generally - carefully remove the steel band / clip that holds on the lower radiator hose, ( replace with a new "jubilee" type work-drive clip)
wiggle off hose from lower rad. stub,
and both Hose + Rad will emit coolant until @95% of system is empty,
as usual - keep heater on MAX / HOT so it's full bore open
and undo the bleed points on radiator and bulkhead supply hose
Yes I agree with this, done it a couple of years ago when I fitted a new rad, bleeding air out afterwards can take a little while, make sure that you find all the bleed valves above the engine in front of the bulkhead, from memory my '97 had two. A replacement thermostat would be a good move whilst you are at it
