- Joined
- Jul 20, 2008
- Messages
- 23
- Points
- 7
Ok, well basically if you have seen my other threads i recently got a Punto which already had a lot of stuff on it.
At the moment i have got the front speakers and back speakers wired up fine and connected to the headunit.
I also have in the boot an unconnected 1000 Watt JBL sub and a Sony Amp (Approx 600 Watt's not too sure)
Basically i was wondering what i need to do so what would work with the Headunit and stuff, there is the red power wire running under the door sills and connected to the battery (well will be when everything else is connected) there is also a black wire (same thickness) running alongside under the door sil, i presume this is the ground but i'm not sure where it runs to though, there is also another earth wire in the boot
There are also 2 plugs same as the speaker wires in the back of the headunit and running to the boot one being black and one being red.
Along with this is the Blue REM which is connected to the headunit and runs to the boot, basically im wondering how i would connect this up and what needs to go where (please note i would also like to connect the speaker wires so they can run through the amp.
Sorry if this is confusing, i'm confused too because i didn't set the previous system up so i have no idea where to start and stuff.
Thanks for your help.
~Morty
~Morty
