CONNECT Nav/Nav+
CONNECT Nav/Nav+
Status
Not open for further replies.
Rich
Former FIAT Obsessive
Torquay
Hello All
Below are practically all the Frequently Asked Questions about the Connect Nav system, all in one easy to navigate section!
  • For information about software updating the unit, click here
  • For information about installing the unit, click here.
  • For information about functionality of the unit, post in this thread.
  • For a list of voice commands, see this thread.
  • For information about connecting an iPOD to the unit, click here.
  • For faults and problems - USE THE SEARCH FACILITY FIRST! If then you have no luck, please post in the Technical section.
  • For the ongoing discussion about the unit resetting track position when switching off, see this post.
  • To obtain Setup Discs or Map Data, please see this thread.
  • To solve the issue with a used Blaupunkt IDC-A09 not playing when installed, see this thread.
Rebooting the Unit
If the unit is experiencing problems whilst driving, a reboot may solve this issue. To reboot the unit without turning the ignition off and back on, simply press "Setup" four times.
Hidden "Service" Test Menu
There is an inbuilt menu in the Connect Nav+ unit that allows the user to ensure various modules are working, and that the speakers, antennas and GPS/GSM systems are functioning normally. To access this menu, do the following continuously and quickly:
  1. Press "Setup".
  2. Press "Connect" 4 times (i.e. push either button 10, 11 or 12 of the 12 buttons along the bottom of the screen).
  3. Press "Enter".
  4. Scroll down to the newly appeared button "Service", and press "Enter".
Turning Screen Off Whilst CN+ Is In Use
Simply push and hold down "Main" for about 5 seconds. Repeat procedure to switch back on.
I will personally ensure this sticky is updated as to when it is required. Please help keep the thread repeats down!
Thanks, and happy foruming!
Rich
Stilo Moderator
Status
