Technical connect nav+ illumination on the buttons
FrankM
herts
Hello, new member , i have a stilo abarth and the illumination of the buttons on the left side of the connect+nav are not working, you can get them to light up with a bang on the unit but they do not stay on. I pulled the unit out and by applying pressure behind the cover you can also get them to work, would Fiat be able to sort out this problem ? or should i just ignore it as the connect works fine, thanks.
Hi, Welcome to the FF.
Probably the ribbon cable that connects the front panel to the motherboard is loose. If you feel competent enough to take the front panel off, removing, cleaning (with electrical contact cleaner) and replacing the connector will probably solve it.
On my CN+ just the Reverse, Play and Forward buttons didn't illuminate. That was a hairline crack in the front panel PCB that I was able to bridge.
Fiat do not repair any electronic components, just fit new ones.
Dave.
