MikeTowers
I have a 1993 Fiat Tipo 1.4ie which has recently developed a cold starting problem. When
the car is warm it runs and starts perfectly. However when it has been left overnight
and is cold it is a real pain to start.
When you turn the key the engine turns over but does not fire. If you keep trying the
car will eventually start although quite often the engine will flood. The best way I
have found to start it is to turn the engine over with the accelerator peddle pressed to
the floor for about 10 - 15 seconds and then release the accelerator peddle. This generally
causes the engine to fire although it might take several attempts before it fires and keeps
running. As the car runs fine when it is warm I suspect this is a problem with some sort of
cold start sensor and not the plugs or HT leads etc.
If anyone you shed some light on the possible cause I would be very grateful.
Mike
Mike
