Technical  Clutch Slave and Bleeding
JoeM
United Kingdom.
I have a Marea 2L 20V, and have replaced the Slave Cylinder for the Clutch - the supposed cause of the Floppy Clutch Pedal Syndrome. But now, how to get it to work? Is it simply a case of bleeding the brakes, or is there some methodology to bleeding the clutch as well? How to do it? I mean, there's no pedal to depress (or there is, but it has no tension). Will pumping the lever into which the cylinder is seated do the trick?
MTIA,
JoeM
follow the line back from the slave cylinder and u'l see that it 's just a tapping off the main brake supply bleeding is as per the brakes
