If you decide to have a stab at it yourself, I would prob be able to come an give a hand. I'm not that far from you
The release arm when moved anti clockwise without the cabe attached should return to the down position on its own when in good working order.
Thanks for your reply. So standing at the front of the car, when the mechanism is working, should it be possible to push the arm towards the bulkhead by hand or with the use of grips like I mentioned or would it need much more force? I can't manage to move it with grips and levering it from underneath the car.
Thanks again, Jon
Ah I see, I thought that the arm had seized because the release bearing had had it and that the pedal was stiff and the cables going because the clutch was on it's way out? Do you think that is not the case?Yeah it should move with ease. I think that is your problem, they are not expensive but you need to take the gearbox out.
http://cgi.ebay.co.uk/CLUTCH-ARM-FORK-FIAT-PUNTO-BRAVA-BRAVO-PANDA-IDEA-STILO-/140423202130?pt=UK_CarsParts_Vehicles_CarParts_SM&hash=item20b1e00552
Ming
Yes will certainly contact him tomorrow to check against the information given here but he does know the situation with me replacing the cable and I had mentioned about not being able to move that arm when I dropped it off. I thought still that it was the release bearing that had failed and was stopping that arm moving and not that it would need a new arm...Not knowing all parts of the system myself I was only going by information given here and from the many past posts by various members on failed cables and the subsequent replies of 'you will need a new clutch'. So I'm unsure really what's going on now until tomorrow as he didn't say anything about this extra part!I would TELL the mechanic of the offending arm, to make doubly sure. Assumption is the mother of all f*&k ups, pardon my french.
Hi thanks for your reply, thought I'd add a little more to the situation also.Hi
Interesting reading about your problem.
Last time I ended up changing my clutch, before doing so I tried to move the clutch release arm as you describe and could'nt. I rekon its just hard to get enough force on it from the angle you reach down through the engine bay.
I tried one of those eyelet cables and it snapped - although i think it would have lasted longer in my case if i hadnt tightened up the bolt through the eyelet. As i think this caused metal fatigue in the cable. They should really use a different fixing.
That clutch has lasted about 25 - 30k miles and i have just bought another one about three years later. Its now noticably heavy and creaky.
I see! I'll certainly keep your advice in mind, thanks.yes thats correct.
Im about to change the clutch again after about 25K miles i think. My cinq has done 121,000 Miles
Im starting to worry the cable could snap any second as the pedal gets more and more heavy.
Last time i just kept swapping the cable and eventually the release bearing went - well dissintegrated, and the fork went into the spring plates. I then had to replace the fork.
Last time I changed my cable I put a washer on before the split pin - as the split pin failed on me. I rekon this is a good idea, as well as carrying a spare cable and a 10mm spanner in the boot![]()
