I had my clutch replaced a couple of months ago and I am starting to have issues.
When the car is cold, the clutch operates fine but once warm it struggles to bite properly, especially on hill starts. I have also noticed gear oil leaking from between the bell housing and block. The box is noisy at idle and in 1st-3rd gears which points to the input shaft bearing (based on posts I have read on here). I mentioned this at the time of having the clutch done but the garage didn't want to split the box and blamed the noise on the release bearing (said they'd never seen a 500 box fail before). I took them at their word and had the clutch done but now I am in this situation. I am guessing that the oil leak is the input shaft seal and the lack of bite when hot is oil on the friction plate?
I just wondered if anyone could offer advice on this/confirm my fears?
Is there a guide to removal and replacement of the gearbox/clutch as I don't fancy paying someone to do the work again. I can get a reconditioned box locally so wanted to do the work myself, providing it's not a horror story to do the job?
Car is a 2010 1.2 Pop with 72k miles.
Thanks in advance as always!
Stevie
Stevie
