Hello, I'm having a bit of trouble with my clutch. The cars never been driven since I've owned it and I'm trying to sort the gears out now the engine is working.
I can select all 4 gears and reverse while the engine is off.
If I start the car...
First and reverse grind if I try to put it in gear with the clutch down, 2nd, 3rd and 4th don't grind but I can't select them, (however the car moves slowly forward as I pull the gear lever towards them as if something is connecting.
I've tightened the bolt at the end of the clutch cable loads, it doesn't seem to make any difference.
The clutch looks like it moves apart???
- Model
- 126p elx
- Year
- 1998
