Right - City light on doesn't mean a Fault
The City light when extra light steering is active
If JUST that light is on - no column needed
But if you have the RED steering wheel - get the Fault Code Read first
Silly things like
Low Battery voltage
Weak Alternator supply
Moisture on the Motor / ECU
Fuse has popped
Motor has a Internal Fault etc
can cause the light to activate but not need the column replacing
Get the fault code - Get back to us
Also check the Guides Section there is Guide about the system in there
ziggy
