Mine, before it started to have this problem, the max temp was always around 90.When the car was moving the temp was around 80, the line under the 90 mark.
Yes the same problem.Works only for a few seconds.But now at least starts to work at 90 degrees.Starts and stops,and going up until it reaches 100 degrees.From then and after it is stayble.Won't go any higher.
Now the online shop that i bought the thermostat has 3 part numbers for the original part.
FIAT / LANCIA: 0007729959
FIAT / LANCIA: 7670764
FIAT / LANCIA: 7729959
I changed the swicth when i changed the thermostat...can the switch have two types like the thermostat?one that turns on at a lower temp than the other?
I changed the switch when i changed the thermostat...can the switch have two types like the thermostat?one that turns on at a lower temp than the other?
Problem solved...but not from me.At friday I took the car to a Fiat garage.And the guy told me that the hose tha feeds the water pump with the expansion tank was blocked by sludge...propably from the previous owner,didn't take care of the car a lot.I wasn't sure if it was actualy the problem so i didn't want to post earlier.
