Hi all - I have lurked around for a while but never posted because all the information I have needed has been in old threads, and I don't have enough knowledge to help others!
I am wondering if someone can give me some help though. The top half of my speedo cable broke recently, and after ordering one incorrect cable (a one piece that didn't fit my old instrument cluster) I then ordered the correct top half based on the chassis number. I took it to get fitted however they said it is too short (which looking at the one it has replaced is true, plus I tried myself and it doesn't reach).
I ordered it from Ricambio who were incredible helpful - the guy said that the chances are someone replaced the cables with incorrect ones which is why the lengths don't match up, so I have ordered a new bottom half now, which means I should have 100% the correct set up for my car.
Basically... what is the best way to fit it? Firstly I am assuming I need to jack the car up to attach the bottom to the gearbox, is this easy enough? Also, how does the cable route to the dash? The old one seemed to go through the bulkhead in front of the passenger seat, go down and run along underneath the dash and then up to the dials, which seems a very long winded design. I would have thought it were much simpler to just go through the bulkhead behind the speedo but there doesn't seem to be a hole there.
Any help would be very much appreciated, thank you
