Technical  Cinquecento Querie
Sunil_FiestaRs1800
Slough, United Kingdom.
Alright peeps im Sunil i own a modded up fiesta Si with an RS1800 lump.
basically my mate has Cinq 900cc and we want to transfer all parts form Cinq Sporting into this. so i need to know what parts i can swap and cant. like do we need to change over the whooe loom to get the engine the running?? does the sporting have different brakes and extra or better anti-roll bars ?? any help appreciated cheers
why dont you just take off the old sporting exterior, and swap it with the good bits from the 900? Would be much easier ;)
Seicento Sporting 1.1 | Current Project : ICE Install
cheers lads. wen u say u need to change the mounts do mean that the mounts are in the same places but are stiffer?? or that the mounts are in different places?? so basically will the engine fit in without havin to weld in new mountin points??
also where can i find out if the looms are compatible cause i would like to avoid changin it if possible for obvious reasons
The shells are the same, you may need the complete mounts (i.e. bit that bolts to the body and the bit on the engine) swapping over.
The 899 and 1108 basically use the same throttle body, same TYPE of sensors (if not identical ones) etc. - it may be worth spending a couple of hours with a Haynes manual and pen& paper to see what's different.
Pete.
Cinq sporting 1242cc
Cinqs&Seis Yahoo group
Clubcento
cheers for the help. we are starting tonight so ill try it on the original loom and if it dont work then ill swap em over. my mates plan to get the engine out is to take the subframe out then drop the lump to the grond on both cars then lift fronts over the engine and then lift the front back over onto the new lump. then we are gonna wire it all up and get runnin. then we are gonna chop the sporting in half and wack it on a small trailor we got and take it down the scrappy. should be fun lol
