Hi
Im having a few issues with my cinq overheating. Basically after running for 10 mins or so water temp reaches about 90ish and the fan no longer cuts in.
I have checked with a piece of wire from battery to fan and even then the fan will not work.
I have emptied the coolant and re-filled and bleed etc as i thought this was the original problem until i realised that the fan was not working.
Also if the car water temp reaches over 100c the expansion tank overflows through the cap and water pours out.
Do you think this is just a fan problem or something more serious ?
