Water pump is weak. Its not pumping enough water at idle.
Change it before you run into bigger problems.
SPD
could it be air cuz when i did the tappits i had to take the water pipe off to get the carb off
That won't help. Didn't you bleed it after, naughty boy.
SPD
no i forgot to bled it after,ill give it a go anyway do i just run the car and take the end of the bleed pipe??
no, you do it cold, make sure the reservoir is topped up and open the valve on the bulkhead first. Then do the front one.
I presume(hope) you haven't been using the car over the last 5 days.
spd
bulkhead??? I only can see the pipe behind the drivers side headlight, were is the other one??? Sorry about this
yours is an 899, so u only have one bleed so bleed it from that
ming
ok thank you, i will put a new tank on while im doing it, it looks weak on the sides
i presume that in the gaps between your posts you are not using the car.
spd
