General CINQUECENTO 1993 red light on dash thinks its the injectors
sunset
CINQUECENTO 1993 900cc, red light on dash thinks its the injectors warning light, looks like a hose pipe with water coming out of the end.. car as no power,think it may be running on 3 cylinders only.. had it for 2days, not sure what i need to do, any help would be great, many thanks in advance...
OP
OP
sunset
sunset
think its sorted.. a lead had come loose of the bottom of the ignition pack(not sure of its real name, trying to buy a manual of ebay).. anyway put the lead back on and it still did not work, so i took a lead of the battery for a few mins, then replaced it, and then tried the car and as if by magic it was running ok...... i like these little cars... first fiat i have ever had..
rallycinq
Autotest Special
Lake District....Moist
With a lead off the 02 sensor would have been seeing unburnt fuel, so would have put the system on to 'limp home' mode.
Resetting the ECU has cured it.
OP
OP
sunset
sunset
cheers and many thanks...
