General Cinq Washer Pump
stevieboy2k
Durham
Hey all, this is my first post to the Fiat forums, and hopefully you can help me with our problem!
My brother owns a Cinquecento SX, and i use it when he's away for uni, and I have just found the washer pump is dead! I've tried filling the bottle, and changing the fuse, but no joy!
With winter fast approaching and it being needed, could you tell me how much they are either new/ from a scrap yard and how easy they are to fit by yourself?
Steve
custard
Status: DEFCON Grumpy
Edinburgh
scrappy a few quid as most.its under the drivers wing.
remove the wheel liner and you can get good access to it.easy job.
does the pump make any noise at all? just thjere known to leak so worth checking the fluid isnt leaking away if the pumps running
rallycinq
Autotest Special
Lake District....Moist
Before dashing off and buying stuff, check the continuity at the plug for the washer motor.
I've seen a couple of dodgy earths down there.
