East Mids Neil
- Joined
- Dec 14, 2007
- Messages
- 24
- Points
- 6
My sons 1st car, bought privately last year with a 12 mth main dealer mot is due again soon. How it got through the last one beggars belief with a rear end knock & a iffy handbrake. The knock was a split rear suspension bush (N/s) which I've changed, but I'm having a problem with the brakes on that side. With the rear end jacked up and the handbrake ON 2 / 3 clicks (very tight) the O/side wheel locks up but the N/side doesnt. The linkage on the N/s also travels much further than the O/s. With the handbrake OFF the N/s linkage seems sloppy compared to the O/s. Having had the linkage off to replace the bush I know it's not seized. The footbrake performance is aslo low on the N/s and the odd thing I notice is that the drum comes off easily (normally they can be difficult to pull over the wear lip on the drum) so I guess it's a problem with the self adjusters. I had this problem years ago on the wifes Uno but cant remember how I fixed it. Does anybody know the most likely cause i.e. worn linkage, loose friction adjusters, stuck hydraulic cylinder.... the shoes are not worn out by the way... thanks in anticipation
