because its newer maybe? lol got to remember they have more "crap" inside so it will be more quite which makes it feel better.
The OP said they have a punto 55.... this is the same engine as the cinq and Sei which meens there all as likely as each other to have a head gasket death. nothing to worry about anyway!
but reallllly if its a car for daily use and little to no modding then get a sei. if you like to tinker then get a cinq.
my sei feels so much better to drive, it is an spi model sporting. switch gear is better and just feels newer.
the age difference between my cinq and sei is 6 months!
but it is a newer design. seicento does feel different to drive. so go and test both if you can, and then choose your fave .
MORE? I would expect the cinq/sei to be harsher due to higher engine temps and what not.Maybe the same engine but the cinq seems to be more reliable for some reason to me on the HG than the punto
true but I would not say its more so then a cinq as its the same chassis.
or maybe its cos the 1.1 is under a lot more stress when lugging around a big fat punto lol
maybe its the same chassis, but engine wise the writing is on the wall for the cinq
Everything recent and current is MPI, something the sei is, which is making engine swaps for seis for the current fiat ranges a lot more viable and easier
The SPI is an old unit now, there is only so far you can take the SPI it will be RIP pretty soon IMO unless you are digging an old engine out of somewhere or converting to MPI, and this is hardly easy.
Lets face it, there hasnt been any interesting conversions cinq wise for ages, whereas we have had the 1.4 seis etc starting to show up more frequently
This is why the sei (MPI one) is slowly taking over from the cinq as the serious modders choice as you have a better starting base,
Interesting.Driving on excatly the same roads though and IMO opinion the cars feel so different, the Cinq feels more solid and a harder ride whereas the Sei is a bit softer and doesn't inspire the handling a Cinq does..
:nono::nono::nono:
Cinq has the cock, sei has the flaps
Lighter my a**, there was around 19kg extra unaccounted for in a '97 Cinq compared to a '98 Sei when I weighed up a few 'centos.To be fair ive been thinking more along the lines of sport use. i reckon. a standard cinq and standard sei. the cinq would run circles around a sei. mainly due to been lighter and by the sound of it the sei has very "fluffy" suspention.
That's why you remap the ECU, the stock MPI ECU is very flexible in that regard.as for the 1.4 thing. like said its only done because the MPI. if it was really worth doing people would just go for a custom ECU (which imho should be done with ANY engine swap. I think using a 1.1 ecu on a 1.2 is pushing it. but using a 1.1 ecu on a 1.4 is way worse!)
A 1.2 16v is a little lighter than a SuperFIRE 1.2 8v with turbo, I duno how much heaver the 1.4 16v is, but I can't imagine it's that much more and also I think the 16v units hold less fluid in mass.surely the 1.4 is one hefter of a lump which CANT be good for the handleing of the car. in the cinq the last thing you want is more weight up front. the rear is always the first thing to go loose.
I am off to look at V reg Sei sporting after work today so will let you know
Cheers again
