Technical Cinq: Front Panel Disassembly
nomatter
Hello folks.
I was wondering what's the way to dismantle the front panel (the one which has the dashboard attached at the driver's side), so that I can reach the space behind it (where the hot air heating up the windscreen comes from).
Also, the right side (not the driver's side) of the panel is not firmly attached: keeps moving and makes sounds while driving.
I tried taking off the dashboard cap (5 hex nuts), but it probably has nothing to do with the panel itself.
Thanks.
custard
Status: DEFCON Grumpy
Edinburgh
you mean the big black cowl?remove the hex screws including the 2 behind the clock blanking plates.
the speedo assembly can be removed easily after that
rallycinq
Autotest Special
Lake District....Moist
Looks to me like he wants to tighten up the full dash assembly, I think he's already had the clock cowl off.
The Dash bolts are in behind the air vents at the ends and IIRC under the centre middle bit.
There are also a couple of screws under the shelves at each end.
OP
OP
N
nomatter
I'll try.
Thanks.
chaos
Ah. Not good...
IIRC there's also some bolts by the speaker mountings :)
OP
OP
N
nomatter
Correct.
By "behind the air vents at the ends" you mean that I should take out 4 black pieces of plastic that direct the air flow, open the vent and search inside of it right?
I couldn't find anything like a bolt inside.
Easy to locate.
Got them.
Now, as the dashboard still refuses to move, do I have to detach the plastic parts from the driver's wheel?
Also, is it safe to try to move the dashboard without risking to loose connections with wires and cables connected to the speedometer , etc?
Actually I want to get inside where the hot air heating up the windscreen comes from to take out something that accidentally rolled in.
Is there any other way?
rallycinq
Autotest Special
Start by taking the instrumet cowl off and remove the instruments. That will save most of the wiring from being damaged.
Remove the complete air vent assembly and the, I think, nuts should be apparent.
