A andygod75 New member Joined Feb 22, 2009 Messages 5 Points 2 Feb 23, 2009 #1 anyone seen this happen before? its happened to my girlfriend on her cinq and now she cant get in through the drivers door, but it will still open from the inside. anyone know what to do? would be much appreciated andy
rallycinq Autotest Special Parked in the garage Joined Mar 19, 2002 Messages 24,592 Points 3,862 Location Lake District....Moist Feb 23, 2009 #2 The complet exterior handle is only held in by one screw in the door jamb. Is it the complete unit thats come out? Cheers SPD
OP OP A andygod75 New member Joined Feb 22, 2009 Messages 5 Points 2 Feb 23, 2009 #3 no the surround is still on, its just the handle, its popped out at one side so ya cant use it to open the door. tried pushing it back in but it wont go. dont know how the hell she's done it
A arc this is where i stand Parked in the garage Joined Oct 8, 2003 Messages 19,719 Points 3,335 Location Manchester Feb 23, 2009 #4 you mean the hinge has bust? i've done that on mine. if you push it up as you pull it, you can still open the door
OP OP A andygod75 New member Joined Feb 22, 2009 Messages 5 Points 2 Feb 23, 2009 #5 could be, its out lasses car. its as though one side of the handles just popped out, is there no way that it could go back in?
A arc this is where i stand Parked in the garage Joined Oct 8, 2003 Messages 19,719 Points 3,335 Location Manchester Feb 23, 2009 #6 i havent found a way, i assumed it had smashed. never bothered looking, i know how to open the door - that'll do
rallycinq Autotest Special Parked in the garage Joined Mar 19, 2002 Messages 24,592 Points 3,862 Location Lake District....Moist Feb 23, 2009 #7 Scrappy will have a used one, and as said earlier only one screw holds it in. Its easy to change the locks over so the same key will work. Cheers SPD
OP OP A andygod75 New member Joined Feb 22, 2009 Messages 5 Points 2 Feb 24, 2009 #8 thanks alot guys
