good progres arc should be good when finnished
wayne
wayne
Part Num. Qty. Availability Line Price Description
Manuf Part No
9760369 3 In Stock 5.79 IC, 8-BIT FLASH MCU;
Microprocessor/cont PIC16F628-04/P
1159699 1 In Stock 2.12 IC, STEPPER MOTOR DRIVER; Driver IC
type E-L6219
9712283 1 In Stock 2.95 CRYSTAL, 4.000000MHZ; Frequency,
output: LF A120A
1100369 5 In Stock 1.65 CAPACITOR, 22PF 100V;
Capacitance:22pF; SR151A220JTR
1100383 5 Awaiting Delivery 2.00 CAPACITOR, 0.1UF 100V;
Capacitance:0.1µF SR201C104KTR
1198320 5 In Stock 0.765 CAPACITOR, 47NF 100V;
Capacitance:47nF; ECQB1473JF
9339051 50 In Stock 0.60 RESISTOR, 0.25W 5% 1K; Resistor
element MCF 0.25W 1K
9497064 5 In Stock 1.65 RESISTOR, 3W 5% 1R0; Resistor
element ty W31-1R0 JI
1099879 50 In Stock 2.25 RESISTOR, 0.5W 1% 330R; Resistor
element MFR4 330R 1%
4142846 2 In Stock 3.04 RECEIVER, IR VERT LO POWER;
Wavelength, HIM702VM.
368106 10 In Stock 0.14 DIODE, HIGH SPEED DO-35; Voltage,
Vrrm:7 1N4148.
9692673 2 In Stock 2.00 CAPACITOR, 0.1F 5V;
Capacitance:0.1F; Vo EECS0HD104H
4701987 2 In Stock 3.08 EUROCARD PROTOTYPING BOARD;
Diameter, PC BP196
what about it.. should be metal? i said that to the bloke in the shop and he didn't agree.
Well, I used to use that kind of stuff for non-pressurised systems. Does he know you're putting 3 bar through it?
it is only the +ve, switched +ve and ground that are soldered. the rest are screwed into the terminal block. this is then cable tied to the ECU bracket. the cables are not being pulled on. like i say though, not finished. loom will be finished when the engine goes back togeter and can see wehre to route stuff.
