cheap power enhancement (warning)
N
new to hgt
just messin around on ebay, came across this link.
im assuming this is one of those things that increases the fuel pump pressure or something and is not good for the engine.
can anyone shed any light??
Just put some lead in your right shoe. Probably get the same effect
Regards
Conrad
or buy a cheap 50p fan turn it on and place directly into air induction pipe could get you about 5bhp!!!!
The gadget that you point on the link will give a wrongly signal to the ECU.
The ECU than will choose "higher" performance maps, which will be not were healthy for your engine.
You can purchase a 10K potentiometer on a radio shack, much cheaper.
If you want to try this, just take your vehicle and get the exhaust gases measured.
You will not believe in the results.
C
1
514
K
R
2
255
OxHGT
O
A
376
anthony jenkinson
A
S
2
437
Dark Lurker
