DickBarton
One of my rear brakelights needs replacing but I can't for the life of me work out how to remove the light cluster to get in to replace the bulb. According to the manual, I undo the 2 bolts and the light cluster should slide out - mine doesn't...it moves around but no matter which way I try to slide it to make it move it won't...how do you remove the cluster?
The shape of the cluster doesn't make it easy to get a good grip but surely there must be a way to do the job?
Thanks.
Thanks.
