Please help! How can I change my cooling water with antifreeze on my bravo 1.6 SX '97?:(
T tzlokovic New member Joined Jan 19, 2006 Messages 6 Jan 23, 2006 #1 Please help! How can I change my cooling water with antifreeze on my bravo 1.6 SX '97?
Deckchair5 Whaddya mean too old? Joined May 1, 2005 Messages 5,607 Location Roman city Bath Jan 23, 2006 #2 Undo all the bleed screws and disconnect the bottom most hose. Not worth keeping the old coolant which will probably get contaminated anyway so top up with new water and and anti freeze mixture
OP OP T tzlokovic New member Joined Jan 19, 2006 Messages 6 Jan 23, 2006 #3 Does exists any valve needed for irradiate the cooling system? In case there is any valve, how can I irradiate the cooling system? Thanks
Deckchair5 Whaddya mean too old? Joined May 1, 2005 Messages 5,607 Location Roman city Bath Jan 23, 2006 #4 There is no valve to drain the cooling system. Just take out the bleed screws and disconnect the lowest hose and let the coolant drain out. Someone may have a picture for your 1.6 engine
OP OP T tzlokovic New member Joined Jan 19, 2006 Messages 6 Jan 24, 2006 #5 Thanks, I appreciate for your help.
