Technical Central locking kit problems...
mufc
Bought the same kit as karbine from ebay, only problem is how can I attach the actuator to the solenoid?? I cant possibly screw it because there is no room behind the lock... :confused:
right. In the bag you also get a clip, this clip, you put the rod in it and screw it tight. We had to drill through the door with one of those massive drill bits, to make a hole about 1.5 inch so we could tighten the rod to the original actuator.
Pics to explain whats wrong would be spot on :)
I got that part.... So you have to drill a hole to get to it hmmmm, not sure If my dad has 1 of those drill bits... I will see tonight
