grandepuntomad
- Joined
- Oct 4, 2007
- Messages
- 72
- Points
- 31
hi my car has been stood for 8 months, tryed stating it, it just tuns over. even with jump leads. car always started 1st time befor i stoped using it
I too am having a similar problem. The car was working fine up until a few days ago, as I drove it to and from the MOT station.
Put tax on it, got it round the corner from my house, all of a sudden the revs just dropped to nothing and I coasted to a halt.
Left it a bit, then tried to start it up again......nothing. Pushed it home and left it for a couple of days.
So far it has had (engine-wise) new plugs and leads (to cure a misfire) and a new crankshaft sensor (as it was showing similar symptoms to a car I'd worked on that needed this part). Still nothing.
All four plugs are sparking, and the injector is putting fuel through.
Tried jump starting as I've never had a problem starting it this way. Nothing.
It just turns over, but won't start, and I'm beginning to think I should push it off the end of one of the piers, as I'm at my wit's end with it!!
i would say have a stab and the ECT (engine coolant temperature sensor) in the head would be causing this problem
its on the left side of the head as you look down it between 2 head bolts, think with a single spade connector on it
Ash
You're looking for the one on the back of the inlet fannymould, check the resistance.
Hi ,have you replaced the fuel filter?
so you must be missing spark, air or fuel as you say there is spark good, air maybe but might not be enough fuel
Ash
