Codebreaker
- Joined
- May 20, 2019
- Messages
- 13
- Points
- 54
After doing some small electrical work (hard wiring phone charger and a dashcam) I could't start the car. I tried it a couple of times with relays clicking and light flickering all over the place so I gave up and decided to check voltage of the car battery which it turns out was 10.3V so I jump-started it with another car, at which time the light for checking glow plugs turned on.
After that, sometimes when starting a car that has been sitting overnight (0-5°C night temperature), I have to crank the car two or tree times for it to tun on. Checking the battery voltage after sitting there overnight it's reading 11.5V. I've been driving the car for total 9h total since the battery drain so I'm assuming that's enough for the alternator to charge the battery (VARTA C30 54Ah 530A) to its full potential (get it? potential? I'll see my self out...). When the car is running and the alternator is charging the battery the voltage is 14.6V. Checking this table that I've found it seams that my battery can't hold a charge and is good as gone. Is that true and should I run to the store right away?
Additionally, before I did any work, there were times when the car couldn't turn on after the key was in MAR position for longer period of time (30 or more seconds). Could that indicate a bad battery?
Given what I just said, could glow plugs actually be ok and its the battery not giving enough energy to the glow plugs thus giving off the warning?
Or is it the other way around and the 11.5V is actually ok for this battery and it's the glow plugs that are causing the starting issue?
Of course I could replace both the car battery and the glow plugs but I want to check here before having to go outside in the cold.
