puntodad19
- Joined
- May 1, 2019
- Messages
- 109
- Points
- 85
it turns out the lads punto evo 2010 does not have the 199A4000 engine, but the boot id plate says it has the 169A4000 sohc 8 v engine, petrol.
He is off work for a week so we can check the actual number on the engine to be sure.
Has anyone used the cheapo cam and crank locking tool kit on e bay for £25!!, better than the Sealey one for over a £100, or is the sealey one made in china as well???
Cam follower shim removal tool, that hooks under the camshaft and allows compression of the bucket enough so the valve working clearance shim can be removed, were can i get one please???
It makes sense to do the valve clearances ( if we can get the shims? ) whilst doing the cam belt inspection and possible change.
thanks in advance.
thanks in advance.
